Nakup ATV-ja v Aziji !
Odgovor Napisal/-a el.presidento » 28 Feb 2006, 00:11
Nakup ATV-ja v Aziji!
Za vse nejeverne tomažke in naivneže, ki še vedno verjamete, da lahko v Aziji dobite identične ATV-je Yamahe ali katerekoli ostale identične ATV-je ostalih znanih blagovnih znamk, le pod drugim imenom, sem se posebej potrudil in sestavil slike skupaj, pa še link do prav tega zavajajočega ponudnika:
http://www.made-in-china.com/showrooms/ ... a_ATV.html
Nataša
Prispevkov: 432
Pridružen: 21 Jan 2006, 14:47
Kraj: Šentlovrenc
Odgovor Napisal/-a Nataša » 01 Mar 2006, 19:40
Hudo :shock: Se je za zamislit!
Odgovor Napisal/-a jaka » 05 Mar 2006, 21:33
Prihaja pa Made in Japan.
Masai 300 avtomatik in 450 ročni(nožni) menjalnik,oba 4x4.Sta v postopku homologacije.
Nataša
Prispevkov: 432
Kraj: Šentlovrenc
Odgovor Napisal/-a Nataša » 07 Mar 2006, 18:47
Ta pa izgleda kot otroška igračka ;)
Odgovor Napisal/-a jaka » 07 Mar 2006, 19:42
Tole bo pa malo bolj resno !
A450
PRODUCT SPECIFICATIONS
Overall Length (mm) 1830
Overall Width (mm) 1090
Overall Height (mm) 1150
Ground Clearance (mm) 275
Seat Height (mm) 850
Unladen Weight (kg) 220
Engine capacity (cc) 448, 4 stroke
Starting System Electrical
Transmission 5 speed with reverse
Max Power 45hp / 8250 rpm
Max Torque 41Nm / 7500 rpm
Cooling method Liquid
Max Speed 105 km/h
Front Brake Dual hydraulic disc
Rear Brake Single hydraulic disc
Fuel Tank Capacity (l) 12.8
Front Suspension Dual A-arm 280mm travel
Rear Suspension Swing Arm 254mm travel
Ignition System CDI
Valve Control DOHC
Bore x Stroke 94 x 64.6
Lubrication Dry sump
Compression Ratio 11.6:1
Homologation Euro-2, Road legal
Colours Blazing Red or
Thunder Anthracite
A270
A300
Overall Length (mm) 1820
Overall Width (mm) 1050
Overall Height (mm) 1120
Seat Height (mm) 780
Unladen Weight (kg) 205
Engine capacity (cc) 265, 4 stroke
Transmission Auto CVT with reverse
Max Power 18hp / 6500 rpm
Max Torque 21Nm / 5000 rpm
Max Speed 75 km/h
Front Brake Dual disc 160
Rear Brake Single disc 220
Fuel Tank Capacity (l) 12.6
Ignition System CDI
Valve Control timing chain
Bore x Stroke 72.7 x 63
Compression Ratio 10.3:1
Colours Dunecliff Yellow or Thun Anthracite Gr
Thunder Antraciteey
Odgovor Napisal/-a el.presidento » 07 Mar 2006, 19:59
KAJ??? 45HP, 105 km/h??? Uffff... tole pa ne bo kar tko... :twisted:
Nikjer nisem zasledil ali je 2x4 ali 4x4?
Cena 6990,- EUR drži za Masai 450?
Odgovor Napisal/-a jaka » 07 Mar 2006, 21:42
Za leto 2007 SYM predstavlja novost-Quad raider 600 4x4.
Odgovor Napisal/-a el.presidento » 07 Mar 2006, 21:46
Tole pa je žvau... boš nabavu Jaka?
pzaksek
Prispevkov: 26
Pridružen: 06 Mar 2006, 14:07
Kraj: Planina pri Sevnicei
Odgovor Napisal/-a pzaksek » 08 Mar 2006, 23:41
ti Jaka ka tisto ko je na prvi sliki gor tud dobiš zraven. :twisted:
Ker jst se je nebi kej preveč branu :D
bombardier atv outlander 400
and ski-doo 600
warrior
Prispevkov: 378
Pridružen: 24 Jan 2006, 11:22
Kraj: zg.savinjska
Odgovor Napisal/-a warrior » 09 Mar 2006, 07:56
ja kdo bi se pa branu take dodatne opreme :D ne vem ča ne bom na sym-a prešaltu :twisted: ....Za to firmo masai sm pa že po ameriških cajtngih dost reklam vidu,samo bolj za športne modele,bili pa so eni izmed najcenejših quadov.
Raptor YFM 350R-prodan
YFZ 450
Odgovor Napisal/-a jaka » 09 Mar 2006, 10:07
OK,fantje,dodatno opremo vam šankam,atv-ja bom pa obdržal. :finga:
