Prodam dodatno luč
Boris
Prispevkov: 280
Pridružen: 14 Sep 2008, 20:45
Prodam dodatno luč
Odgovor Napisal/-a Boris » 12 Dec 2008, 23:00
Prodam malo rabljeno luč za atv priklopi se na 12v če ga seveda ima vaš atv.Cena 90€
hurco
Prispevkov: 1017
Pridružen: 13 Maj 2007, 21:35
Kraj: škofja loka
Odgovor Napisal/-a hurco » 12 Dec 2008, 23:08
slika, lastnosti???
Boris
Prispevkov: 280
Odgovor Napisal/-a Boris » 13 Dec 2008, 08:29
Zadnjič spremenil Boris, dne 20 Dec 2008, 20:34, skupaj popravljeno 1 krat.
roCkY
Prispevkov: 40
Pridružen: 05 Maj 2007, 18:42
Odgovor Napisal/-a roCkY » 13 Dec 2008, 11:15
Tehnične karakteristike?
Boris
Prispevkov: 280
Odgovor Napisal/-a Boris » 13 Dec 2008, 11:35
Lastnosti:RAM High Intensity Rubber Spotlight
* Durable rubber housing with handle
* Resistant to water and weather corrosion
* 4.25" (PAR 36) sealed beam light bulb
* 70,000 Candlepower (as standard)
* 10' (4.8m) coiled power cable
* Fused 12 volt cigarette lighter plug
The RAM spotlight has a durable rubber housing with a handle incorporated in to the moulded casing. The rubber housing is resistant to both water and weather corrosion and will float should it accidentally fall overboard.
Its designed to absorb vibration and protect a 4.25" 70,000 Candlepower PAR 36 sealed beam light bulb. The maximum candlepower (or brightness available is 250,000) and is achieved by replacing the existing bulb. A rubber protected on-off push button switch is included.
The RAM Spotlight unit has a 1" diameter B size ball to allow you attach onto different RAM ball base mount and socket arm systems.
Pero
Prispevkov: 1328
Pridružen: 24 Okt 2007, 22:11
Kraj: Zgornja Kungota
Odgovor Napisal/-a Pero » 13 Dec 2008, 20:46
Če s to lampo ponoči osvetliš zajca, od šoka pogine... :lol:
Po turi paše pošten počitek:
Boris
Prispevkov: 280
Odgovor Napisal/-a Boris » 30 Dec 2008, 08:48
Luč je še naprodaj :idea: 8)
Odgovor Napisal/-a Civava » 30 Dec 2008, 13:17
Pero napisal/-a:Če s to lampo ponoči osvetliš zajca, od šoka pogine... :lol:
Pero ne draži zdaj bomo pa spet tri strani pljuvanja deležni od raznih pametnjakovičev :D :D .
l.p.
Skip
Prispevkov: 336
Pridružen: 10 Okt 2007, 02:15
Kraj: Borovnica
Odgovor Napisal/-a Skip » 30 Dec 2008, 13:44
Civava napisal/-a:
l.p.
ne ne ne,ta lampa je zato,da ko srečaš zajca,da vidiš v njegov želodec,pa če je kaj takega pojedel ga lahko rešiš pred smrtjo!!!
Axa
Prispevkov: 42
Pridružen: 04 Jan 2009, 18:04
Odgovor Napisal/-a Axa » 04 Jan 2009, 18:08
Ali še imaš naprodaj luč?
Boris
Prispevkov: 280
Odgovor Napisal/-a Boris » 05 Jan 2009, 08:30
Še je ja, :idea: če te zanima pošl zs.
boško
Prispevkov: 24
Pridružen: 05 Jul 2007, 08:41
Kraj: Maribor - okolica
Odgovor Napisal/-a boško » 05 Jan 2009, 21:05
Ta luč bi bila super za jagre... :D
